2009 pontiac vibe 1.8l transmission code
Posted: Fri Aug 11, 2023 12:37 pm
by Dreadnaugh
I'm trying to figure out what transmission my 2009 pontiac vibe 1.8l with 101,000 miles has so I can buy a new automatic transmission filter, I've looked everywhere (owners manual, different parts websites and different Vin decoder websites) but couldn't find any information.
Any help is appreciated.
Re: 2009 pontiac vibe 1.8l transmission code
Posted: Fri Aug 11, 2023 6:43 pm
https://en.wikipedia.org/wiki/Toyota_U_transmission says for 2009-2014 1.8L Matrix base, its U341E
Posted: Sun Aug 20, 2023 7:44 pm
by Dreadnaugh
Thx, now I need to figure out how much fluid it needs.
Posted: Wed Aug 23, 2023 9:28 pm
by jolt
Count the number of pan bolts in your transmission pan and get the filter that has the pan gasket that has the same number of bolt holes in the gasket. You can also look at the pan gasket shape and match that to your pan to figure out which filter kit you need for your transmission.
If you pull the dip stick for the transmission, it is stamped on the dip stick what fluid to use for the transmission. My 2009 2.4L uses "WS" type transmission fluid. Do not use the fluid listed in the owners manual, as it is printed wrong.
