2009 AWD Right Rear ABS sensor discontinued
redseed
Post by redseed »
Apparently GMC isn't making this part anymore! :twisted: :evil:
I am guessing the Matrix right rear ABS sensor won't work? Other Vibe/Matrix ABS sensors are interchangeable, but it doesn't appear that this one is? What is the fix here? We will be cleaning the connection tonight and hoping that fixes the code. It came up when the axle seal was replaced.
Can't believe GMC discontinued this part!!
Thanks for any help.
SeattleJeremy
Re: 2009 AWD Right Rear ABS sensor discontinued
Post by SeattleJeremy »
Yes, the Matrix right rear sensor should work.
Brake and drive train is all Toyota parts.
GM typically stocks common parts for 5-10 years. You're car is nearly 15, this is normal in the auto industry.
Want to sell:15' BMW 328i Sport - Jet Black - Auto
Daily 19' Toyota Camry SE Hybrid - Galactic Aqua Mica - eCVT
redseed
Post by redseed »
Thank you very much for the response! It's appreciated friend. :D
Vikingjedi
Post by Vikingjedi »
Hey any update on this? I'm having the same issue. Did the Matrix sensor work on your Vibe?
