2003 vibe electric issues
Posted: Thu Mar 23, 2023 6:55 am
by Svensvibe
Stereo stopped, then fob and interior lights, and speedo and tach surge when ignition turned on? Fuses seem fine . Any suggestions greatly appreciated.
Re: 2003 vibe electric issues
Posted: Thu Mar 23, 2023 6:58 am
by andrewclaus
"Fuses seem fine" sounds vague. They have to be pulled and tested with an ohmmeter or continuity tester.
Posted: Thu Mar 23, 2023 7:22 am
by Svensvibe
Thanks. I pulled and visually checked what I could. Looked for loose wires too. The gauges flicking on make me think it’s a main fuse. Just guessing.
Posted: Thu Mar 23, 2023 8:11 am
by andrewclaus
A blown fuse should not cause the meter behavior. The meters are getting a voltage surge on start-up. That's a normal check for some cars. Do the meters work normally when driving? If the car is drivable, the important fuses are okay.
Not all fuse failures are visible. They should be electrically tested.
Also check the battery voltage when cold and when being charged by the alternator. How old is the battery?
Posted: Thu Mar 23, 2023 10:14 am
Back when I was learning how to tweak Vibe odometers, sometimes when putting it back in the car, the tach and speedo would do a full scale sweep, as if it was doing a calibration.
The interior lights and fob receiver could be either the dome or door fuses, both get power all the time (no relays/ignition switch) The radio gets power from the CIG fuse, after being switched by the ignition switch.
Hard to find a single thing that would cause all of the issues but still let the car start and run normally
Posted: Fri Mar 24, 2023 5:45 am
by SSizler
If the car has rust you should check for a bad ground.
Ground problems cause these types of symptoms.
