I have a 2009 Vibe GT with only 91K miles on it, but it shakes in drive when stopped at a light. I suspect it is the motor mounts, so I took it in and they confirmed that they need to be replaced. They also told me that they are discontinued and there was nothing they could do to fix it.
I know the GM parts are discontinued for a couple of the mounts, but isn't there an aftermarket replacement? Will a Corolla or Matrix mount work? Can someone provide me with the part numbers I need to look for. I'm not sure if it is just the motor mounts, or if I should also replace the transmission mounts at the same time.
Any help would be appreciated.
Nick
