Episode 4 is up!
Video is a bit backlogged so currently I have the trans out at MWR getting an Mfactory LSD installed. Pulling the calipers and valve cover today to prep for paint. Unfortunately I have a deadline of NOV 9TH to finish this so I'm rushing...
I could really use advice on polishing the intake manifold runners, replacing lift bolts, checking VVL screens, general maintanence or things I should look for while I've got access? The car has sat for 3 years so I'd like to really give it a good once over and check anything that needs it. It's got 165k miles and I've had it since 107k. Sadly no clue on past history.
I've yet to really give it a good clean and check for leaks but I'll do that right before I wire wheel all the rust I can find.
Any recommendations on good spray paint to use to cover exposed bare metal and protect it from rusting again?
https://youtu.be/mR410G80Cgw
