Power Steering Fluid
blue_can
Post by blue_can »
Thinking about flushing the power steering fluid - no issue but thinking about doing it as it has never been done and the fluid is quite dark now and some dark residue in the reservoir.
According to the service manual the fluid is Dexron III - is this correct? Since this is a Toyota engine I was not sure if this is more likely to be the Toyota ATF. Does anyone know?
'07 Vibe
Mark
Re: Power Steering Fluid
Post by Mark »
The manual for my 04 and 05 both specify Dexron-III
Haven't done a flush, I just suck what I can out of the reservoir with a bulb baster and add fresh to replace it.
blue_can
Post by blue_can »
Mark wrote: Sat Jun 25, 2022 9:16 pm The manual for my 04 and 05 both specify Dexron-III
ok thanks - I guess I will use Dexron III.....
'07 Vibe
