Aftermarket wheels ..are stock lug studs long enough?
Mac1
Post by Mac1 »
I had a Saturn a few years back and ordered aftermarket wheels for it only to find out the nuts only had 3 turns before tightened.I had to install 20 lug studs that were longer to give the nuts enough threads to be safe. Anyone with insight on this? I have an 05 with aluminum wheels and the nuts go inset into the wheels...
Bookworm
Re: Aftermarket wheels ..are stock lug studs long enough?
Post by Bookworm »
My 03 vibe had aftermarket aluminum wheels, with spline nuts. The lugs were long enough for that. I suspect it depends on the wheels. If you want wider wheels, probably not.
