AC Drain Clogged
Posted: Sun Jun 05, 2022 5:42 pm
Hello All! This is my first post, so apologies if it is not posted in the correct section of the forum!
I believe my AC drain is clogged, and was wondering if anyone would have some insight/instructions/videos on how to unclog it (or other advice if the problem is not a clog). The drips come from a small black box under the glove compartment. It only leaks when the AC is/has been on, and flows mostly heavily when going around a left curve (a squeaking/whishing sound also occurs). The white tube under the floorboard carpet seems to be intact.
Here is an image that shows the location of the leak: https://imgur.com/a/mGrp5w9
Thank you!
Thank you!
