18's fitting perfect
Posted: Sun Sep 14, 2003 7:47 am
by SkateForLife86
Do 18x7/7.5 rims fit perectly in base vibes? i.e. no wheel rub or anything that would shorten the life of a tire. thanks a lot
Re: 18's fitting perfect (SkateForLife86)
Posted: Sun Sep 14, 2003 11:02 am
by SkateForLife86
sooooooo..........how's every little thing..............
Posted: Sun Sep 14, 2003 11:24 am
by MadBill
Well, Skate, since no one with 18s is rushing to reply, let me say that:1. The wheel diameter is not a factor in clearance unless you get really ridiculous. Offset plus tire width and diameter are what matter.2. I have 17" x 10" wheels on my Vibe (lowered ~1-1/4") and they clear fine. The 275/40 tires are tight, but I'm sure you plan something more modest!3. I had these wheels lying around, so I used them. If I was buying new, I wouldn't go beyond 245s, at something close to stock diameter. 4. 245/40 x 17"s equal the stock diameter.5. 235s would likely be necessary with 18" to do the same.6. The specification section at a site such as
http://www.tirerack.com has all the data needed to match stock diameter.7. Research twice, buy once!
Posted: Mon Sep 15, 2003 1:13 am
by Nervous_Dog
I've got 225/40/18's on 18x7.5 rims with no rubbing. I believe my offset is +38 and I think the normal offset is +35. 3mm isn't that big a deal unless you are involved in some type of racing.Handy tire size calculatorhttp://
www.j-body.org/library/tire.php
Posted: Mon Sep 15, 2003 11:13 pm
by mwebb
!8's will fit just fine- I have 18x7.5 with no problems- 19's said to be the biggest you can go on the vibe-
Posted: Tue Sep 16, 2003 7:36 pm
by Lancer
18" Enkei's on my Vibe w/ a 2.2" drop. No problems, only love.
Re: 18's fitting perfect (Lancer)
Posted: Wed Sep 17, 2003 12:44 pm
by ilquikgtx
looks good lancer !!!!!!!!! Wonder where you got your springs from
Re: 18's fitting perfect (ilquikgtx)
Posted: Wed Sep 17, 2003 2:58 pm
by Lancer
Some shady character who sold them to me from the back of his SWEET Vibe.Thanks! I love how they turned out. It looks better in person.
