Rear creaking noises 2005 FWD vibe
Posted: Sat May 14, 2022 8:56 am
I have a 2005 Pontiac Vibe FWD, 208k miles.
It has a creaking noise mainly when getting in or out of car, barely hear anything otherwise while driving.
I had replaced the front struts because they were original after 200k miles and has shaking over bumps, that fixed that issue.
The rears also look like original KYB struts, the strut assembly looks great, dry as a bone, upper mount rubber looks fine, I don't think I really need to replace them.
The trailing arm bushings are a little cracked but don't look too bad.
Should I just try some lithium grease spray? Anyone else have this noise and fix it? Not sure it's worth the time honestly, car is great mechanically otherwise though.
