2009 Vibe 2.4 Auto Arced Alternator - No power
Posted: Mon Aug 23, 2021 7:31 am
by adamp1027
Forgot to undo my battery and arced across the power wire on alternator with a screwdriver. Now I have no power door locks, no windows, no accessories power, no blower motor, no ignition. I have dash lights, headlights, dome lights, that's it. Have checked all fuses in under hood fuse box and under dash fuse box, none are blown. Where should I start next? I was thinking ignition switch.
Edit: i do have horn and hazard lights
When i push the unlock button on the key fob, both blinker indicators on the dash click on and off a few times, but locks do nothing
Also, the gear position is not displayed on the dash, so neutral safety switch probably doesn't have power either
Re: 2009 Vibe 2.4 Auto Arced Alternator - No power
Posted: Mon Aug 23, 2021 12:57 pm
by adamp1027
Removed 120a alternator/main fuse (PITA), and found the alternator section blown. Will order new part and see if this fixes everything
Posted: Mon Aug 23, 2021 5:34 pm
by adamp1027
Replaced alternator fuse, now I have auto door locks! Woohoo! But all other problems remain, what next?
Posted: Mon Aug 23, 2021 6:58 pm
by adamp1027
Replaced ignition switch, no change :(
Posted: Tue Aug 24, 2021 2:45 am
by zbyers
i would suspect some fuse, relay, or module to have gone bad when you shorted it out.
Posted: Tue Aug 24, 2021 6:17 am
by adamp1027
Yes, need someone with wiring diagram who can tell me what to test with my multimeter to trace the problem.
Posted: Tue Aug 24, 2021 9:11 am
by adamp1027
Checked 3 relays behind blower controls, all good
Posted: Tue Aug 24, 2021 3:38 pm
by adamp1027
Just measured good resistance between alternator and fusebox, so cabling there is good. Also, I have 12v at the alternator.
Also have power at the ignition switch.
Posted: Thu Aug 26, 2021 12:23 pm
by adamp1027
I got the diagrams from alldata.com and it saved my bacon
I started tracing the entire power path backwards from the radio to the battery
When I got to the AM1 fuse, I realized there was no fuse there! :oops:
When I had checked all the fuses under the dash, I had gotten the image turned backwards in my head and put it in the opposite corner slot!
In case anybody cares, the AM1 fuse under the dash sends power to the ignition switch (red wire), when you turn the key to ACC, the grey wire is powered from the ignition switch and heads out to the ACC relay, then the ACC fuse, then to the radio.
All fixed!
Posted: Thu Aug 26, 2021 2:22 pm
by Caretaker
Well done; congrats. When I'm upside down looking at fuse boxes, I feel like Jim Lovell trying to maneuver the LEM as sweat pours all over me.
