09 Rattle/Vibration/Engine Hesitancy between 1500-2000 rpms
shawnsmith15
Post by shawnsmith15 »
I've seen similar issues discussed in long ago threads but with no resolutions. My 09 2.4 AWD Vibe with 60,000 miles is doing a strange thing where between 1500-2000 rpms at cruising speeds I hear anything from a rattle in the lower drivers side engine area kind of by under my feet, to an all out feeling like the floor of my car is going to fall off. It started off as an occasional tin can sound, but now has gotten worse.
Right now, I have it at my mechanic and he's stumped. He's checked the exhaust and catalytic converter and can't find where it's coming from. He's saying he may refer me to a transition specialist. :?
Just wondering if any else has had/solved this issue. Thanks!
Shawn
jdrahos
Re: 09 Rattle/Vibration/Engine Hesitancy between 1500-2000 rpms
Post by jdrahos »
Hey Shawn,
Did you ever get to the bottom of this? I think I'm having the same issue.
Thanks,
James
adamp1027
Post by adamp1027 »
I've noticed a similar issue in both of my vibes, 1.8 and 2.4. It only happens at those low rpms when you attempt to accelerate. I think the extra stress between the engine and torque converter at those low rpms causes some extra shaking and the heat shields are rattling.
