03-08 Vibe Exterior-Rocker Molding Clip
03GTMatthew
Post by 03GTMatthew »
Hello all,
I'm wanting to fix the front door rocker molding. The clips have busted off and I'm not sure of the correct ones. Also how would I remove the molding without busting these off? Suggestions?
2003 Vibe GT
I've seen this but I'm not sure the trim is the same because mine doesn't have any clips under (part 3 in picture)
https://www.ebay.com/itm/353464243603?h ... SwmNxadkwx
https://imgur.com/a/qM3IVfh
03GTMatthew
Re: 03-08 Vibe Exterior-Rocker Molding Clip
03GTMatthew
I’ve ordered this set, hopefully I can get one of them to work for the door.
Car Retainer Clips 32 Most Popular Sizes Fasteners 729 PCS Automotive Plastic Clips
[url]https://www.amazon.com/dp/B081JGSM4S[\url]
Mark
Post by Mark »
Hard to tell for sure from that drawing, but if you have a NAPA close by you can take one there and match it. The one in your pic is easy to find at most part stores, especially if you take one with you to match size.
03GTMatthew wrote: Fri Aug 06, 2021 10:16 am I’ve ordered this set, hopefully I can get one of them to work for the door.
I ordered this exact kit a year ago or so and it already came in handy when I had to replace SEVERAL bumper retainer clips! :o I'm one of those drivers who always drive OVER the parking blocks and every now & then they are a bit taller than what I'm used to and they scrape the underside. Which eventually leads to clips falling out :x
