How to remove plastic pillar cover, Passenger side
Posted: Fri Jul 09, 2021 8:31 am
by coppens1
Dear fellow Vibe owners, I need to remove the plastic pillar cover, on the front Passenger side of my 05 Vibe, to look at a leak there. How do I do it? Does it just pop off? Do I use a screw driver? Please provide details, including a photo, if possible. JC
Re: How to remove plastic pillar cover, Passenger side
Posted: Sun Jul 11, 2021 10:12 am
by jolt
Here is link for removing the head liner. It shows how to remove all the pillar covers.
https://www.madstyle1972.com/Repair/76/ ... 040001.pdf
Posted: Mon Jul 19, 2021 1:49 pm
by dougreed
Yes, it just pops of. It may be tight, but it is held in with plastic "christmas tree" type push pins. I just pull the rubber door seal loose and start wiggling the panel as I pull and it pops right off. If there is a leak you really should seal it on the outside of the car.
