2003 Vibe Piston Soak
Posted: Wed Mar 31, 2021 11:49 am
03 Vibe Base Auto w/ 128k miles
I recently ran seafoam high mileage through the crankcase and gas and just replaced the oil a couple days ago at 128,000 miles (Valvoline 5-30 synthetic blend high mileage).
With the weather getting nice I was gonna do a piston soak since I have been told the 2003 1ZZ-FEs are prone to seized piston rings. I also plan on replacing the ignition coils at the same time.
I know how to do the soak as to not water log the engine.
Is there anything wrong with doing the soak if oil consumption is normal for a 1ZZ-FE? When I was running conventional it was close to 0.20 quart of oiled burnt per 1000 miles. Or 0.60 of a quart burned every 3000 mile oil change.
Thank you for any advice or discussion
