Squeaky door
Posted: Sat Mar 06, 2021 9:29 pm
by radioarno
hi all, 2004 base vibe, driver door sounds like its about to fall off what I open it. Not sure if when I close it, maybe, mybe not, but certainly when I open. I figured the hinges were rusty, but can't really get at the hinges, but there's this plastic looking black thing, might be plastic, might be metal, squarish cross section, maybe about 5 or 6 inches long, that slides in an out of the door as it oepns and closes. I stuck some silicone grease on the visible part, and that seems to have improved it maybe 40%, and I'd like to know what else can I do? thanks.
Re: Squeaky door
Posted: Mon Mar 08, 2021 5:30 am
by zbyers
I believe the piece you are referring to is the door check strap. They're reasonably priced online, so you could try replacing it to see if it solves your issues.
Is it possible the door is hitting the fender? We hit a deer in ours, and it pushed the fender back a hair so the door taps the fender and makes a scrapping noise.
Re: Squeaky door
Posted: Mon Mar 08, 2021 8:47 am
an easy test would be to unbolt the door check from the door jamb and see if the door still squeaks when you move it back and forth.
Re: Squeaky door
Posted: Tue Mar 09, 2021 2:27 pm
by radioarno
great advice. Thanks.
