Exhaust system 2005 Pontiac Vibe
Posted: Fri Mar 05, 2021 6:29 pm
by jmvvibeowner
Hi, I have the original exhaust system. Had loud noise and brought to a local garage. They said there's a hole in the catalytic converter and it needs to be replaced. They say they can only get a factory catalytic converter that costs $1,200. I saw aftermarket catalytic converters online much cheaper. I live in Massachusetts. Do I need to get the factory part? Also, in MA they do not do emissions tests after 15 years. Can I get just a straight pipe instead and not put in new oxygen sensors or the catalytic converter? On top of this, they said I need new exhaust all the way to the rear, so total cost is $2,400. Seems like a lot of money.
Re: Exhaust system 2005 Pontiac Vibe
Posted: Mon Mar 08, 2021 5:32 am
by zbyers
They are assaulting you on the price.
Is it FWD? AWD?
FWD, there's plenty of universal ones you could use. Take it to an actual exhaust shop and they can help square you away.
AWD, the cat is in the manifold, and it is pricey to get.
Posted: Wed Mar 10, 2021 3:20 pm
by jmvvibeowner
Thank you for your feedback. It is a front wheel drive and we did take it to an exhaust stop and they are going to put a new cat in and weld the areas on the pipe where there are a few small holes. The exhaust system as a whole is pretty solid. Said it would cost about $575.
Posted: Thu Mar 11, 2021 4:01 am
by zbyers
Still seems expensive, but a lot more reasonable. If they're installing a bolt on converter, that would make sense.
