2005 Pontiac Vibe Door Locks Problem
Posted: Tue Feb 23, 2021 5:24 pm
by jmvvibeowner
I have a problem with my front door locks. The driver's door lock I can turn the key to the rear to unlock the door, but can not turn the key to the front to lock the door. But on my passenger's door, I can turn the key to the front to lock the door but can not turn the key to the rear to unlock the door. I thought I am supposed to be able to turn the key in both directions to lock and unlock the doors, but do not know what's wrong. Any ideas? Also, these are power locks, but I want to be able to use the key to lock and unlock the doors.
Thanks.
Re: 2005 Pontiac Vibe Door Locks Problem
Posted: Tue Feb 23, 2021 5:51 pm
by Mark
If you have mostly used the fob to lock/unlock the doors until now, then the key has worn with the ignition and the door locks remain in an unworn state. My 04 was so bad that when the battery died I wasn't able to open the door, and I had to have a locksmith look up the VIN and cut me an original key.
That's been ten or more years ago now, not sure he'd still even be able to get the key code from GM. If you have a spare key that you haven't used much try that on the doors, if it works then get some copies made asap.
Posted: Tue Feb 23, 2021 6:43 pm
by CraftsmanQuad19
Not sure where you’re located, but is it possible the lock cylinders are just iced up?
Posted: Wed Feb 24, 2021 4:04 am
by zbyers
Mark is definitely on the correct path. The lock cylinders are probably stuck due to lack of use. Some lubricant like WD-40 or silicone spray should help free it up. If that doesn't do it, it's likely due to the key being worn, but the lock cylinder not.
Posted: Wed Feb 24, 2021 5:54 pm
by jmvvibeowner
Thanks a lot guys! I agree that it is probably from lack of use. My car is 15 now and has 218,000 miles on it. I hope I can get a new key cut because it still runs great! I have not used my keys as much and have relied more on my remote. I will see if I can get a new key cut with my VIN number. MY ex used to get the keys cut so maybe he can do it as he still works at a dealership!
