So about 3 months ago I noticed that when I was at a red light or parked idling, the engine started to sag down or sputter down losing a bit of power, almost as if it is begging for more gas. Every time it did that I would just press the accelerator down so as to give it lots of gas and maybe 'clear its throat'. However in the last months its happened more frequently.
Now for the past month, the symptoms has gotten worse in that my right-turn signal is behaving strange as well. When I use my right-hand turn signal, the flashing light and associated clicking sound is way faster than usual. Like its double-time the cadence than it used to be. And also when I use it, the radio face LED backlights kind of flicker when I use it. In addition to this, recently every time I go to start the car, the engine has become weaker and weaker each time almost as if it has no power. Yesterday when leaving work, it barely turned over but thank god it started. When I got home, I turned off the ignition, and tried to start her up again, and nothing. It doesn't even make a sound.
So to summarize the symptoms:
- -engine sagging/sputtering when parked or at red light
-right-hand turn signal double the cadence
-radio faceplate LED backlighting flicker when using right-hand turn signal
-engine now does not crank when I turn on the ignition
Thank you.
