Airbag SRS light- SOLVED with Airbag Control Module
Posted: Sun Dec 20, 2020 1:45 pm
Thought I'd share some info that I didn't find elsewhere on this site. I would make this post short, but this was so frustrating that it will be therapeutic to me to share the whole story. Well, here is the short version- I had an airbag light come on, and had to replace the clockspring (many times), and when that didn't turn off the airbag light, I replaced the Airbag Control Module (once) on my 2004 Pontiac Vibe AWD. If you don't want to read further, here is the important info- if you have a persistent airbag light and have to replace the airbag control module, ignore the companies that tell you that it has to be reprogrammed for your VIN. That is not true (unless, perhaps, you have a used module from a vehicle that had an airbag deploy).
My airbag light turned on when I turned made a left turn off the highway. After a little research, I figured it was the clock spring. I jumped the OBD2 pins with a paper clip (see here: https://priuschat.com/attachments/prius ... jpg.73749/), turned the key to the on position, and counted the number of times the air bag light flashed on the instrument panel. You might see it flash once, then several more times, and then it will either repeat the sequence or flash a different error code. In my case, it flashed once followed by 9 times and then once followed by 8 times.
See here for a list of airbag error codes: http://www.tcorolla.net/diagnostic_trou ... t-737.html
In my case, 18 flashes is error code B1181/18 and 19 flashes is B1182/19. Both point towards the clock spring (Toyota part number 84301-02110). Rather than spending $230+ for an OEM part, I did the right thing and ordered a cheap clockspring off of ebay for $10 (safety first!!!). I removed the old clockspring and installed the new one following a helpful post on genvibe:
https://forums.genvibe.com/phpBB3/viewtopic.php?t=45702
Unfortunately, the airbag light remained on after installation of the eBay part. In fact, I now had three error codes- the same codes as before, plus a new B1180/17 code, also pointing towards a bad clock spring. So I asked for a refund.
Next stop was the local pick 'n pull. I found a 2004 Matrix and pulled the clockspring. Installed it in my Vibe and had a B1182/19 code. Returned to the yard and exchanged it for a clockspring I found on a 2005 Corolla (all part numbers the same). Same error code. Tried "resetting" the airbag control module both by leaving the battery disconnected overnight, and following this procedure: https://www.toyotanation.com/threads/ai ... t.1631410/. I used the same OBD2 pins as used to check the airbag light, and ran a jumper cable from the negative terminal of the battery to use as a ground. Maybe this will work for others, but it didn't for me.
Since I had zero luck on 3 clocksprings, I started thinking it might be the airbag control module, located under the center console, behind the trash bin. You can check your specific part number by unhooking and pulling the carpet down on the passenger side of the center console, and you should see a metal box attached to the floor with yellow wire connections pointing toward the rear of the vehicle. My part number was OEM Toyota 89170-01110 which is also GM part number 19205561. I searched for a used one on eBay. You will see that a different part number, 89170-01100 is readily available on the cheap, and the Toyota parts sites say that the part numbers are interchangeable. However, knowing that some of these modules have been recalled in the past, and knowing that there are no open recalls on my Vibe, I thought I should stick with 89170-01110.
This is what worked for me, and maybe I got lucky. I found a salvage yard on eBay that lists their parts with the VIN number of the car the part came off of. I pulled that VIN number, searched on the NHTSA recall website, and found the vehicle had no open recalls, which meant that any airbag recalls had been addressed. Next, I googled the VIN of the donor vehicle, and found pictures of the vehicle at the salvage yard and saw that the airbags had not deployed prior to salvage. I purchased the part for $49 total (new from Toyota is $154, from GM is $276). You could go to the salvage yard and do the same thing, but I didn't have the spare time.
I removed my center console following this helpful guide: https://forums.genvibe.com/phpBB3/viewtopic.php?t=45913. I did not need to completely unhook the AC outlet/cigarette lighter console, I just removed the bezel and pushed it aside.
Next, disconnect your negative terminal of your battery. Then you need to remove the three wiring harnesses on the airbag control module, and 3 bolts that secure the module to the floorboard. You can pull the HVAC ducts back several inches towards the rear of the car for better access to the wiring. Connect and install your replacement module. From start to finish this probably took 20-30 minutes.
Lucky for me, I turned the key on, and the airbag light went off after about 7 seconds!
The other bonus is that I was able to replace the HVAC light bulb that has been out since I bought the car while the center console was disassembled- found one in the junkyard!
