Troubleshooting noisy/knocking engine
Posted: Mon Dec 14, 2020 5:38 am
by smash
Hi all, original owner of a 2009 Base Vibe, 1.8L engine. 70K miles, mainly in-city driving, with a 25 mile/65mph run a couple of times/month.
Last month, my oldest got back from taking it on a camping trip, and when I went to start it up, I was surprised at the engine producing more noise than I'm used to - I had to check that I wasn't in a Diesel Jetta! At startup & at initial acceleration, I hear knocking, and a bit noisy. At speed, it is less noticeable, but maybe just covered up by tire/wind noise.
So far I've done the following:
- Checked oil - was 1/2 qt low, changed it
- Added a bottle of gas treatment (in case they got crappy fuel), have run 2 tanks of "known good" (Costco) fuel, noise remains. In-town mileage is still at 29 mpg, so whatever this is, is not affecting mileage
- Checked air filter, ok, cleaned MAF sensor.
ToDo: Clean throttle body once I get a replacement clamp for the air hose as the original clamp is rusted shut.
Asking the community for ideas on "next steps" to try to troubleshoot what this might be, or whether this is just normal wear-and-tear for an 11+ year old engine...
Re: Troubleshooting noisy/knocking engine
Posted: Mon Dec 14, 2020 5:51 am
by andrewclaus
A little more description of the noise would help.
Valve train noise will be tapping from the top of the engine. Louder knocking noise from the engine block could be from a piston or connecting rod. An exhaust leak will be a rapid series of muffled explosions. You can narrow down the location with a mechanic's stethoscope. My dirt bag version is 2' piece of heater hose.
How long was it between checking the dipstick? How long ago was the previous oil change?
Have you checked the coolant level and condition?
Throttle body isn't causing this. I'd find this issue before you do any more work.
Posted: Mon Dec 14, 2020 6:00 am
by Caretaker
These oil burners hate being low on oil and aren't especially fond of freezing temperatures. Having nursed mine through many winters, I know. The car sounds eerily loud at startup ESPECIALLY when it is moist/high humidity in winter mornings. Once the oil sloshes around, it quiets down. Only if you hear very loud knocking (like a diesel Mercedes), and as long as the noise gets noticeably quieter after 2 blocks of driving in freezing temperatures, I would not worry about it. Welcome to the world of a 1.8 liter engine that Toyota strung out over 4+ decades with few enhancements.
Posted: Mon Dec 14, 2020 6:19 am
by zbyers
Caretaker wrote: ↑Mon Dec 14, 2020 6:00 am These oil burners hate being low on oil and aren't especially fond of freezing temperatures.
The 1.8L doesn't burn..Well, at least not like the 2.4L.
Posted: Mon Dec 14, 2020 7:38 am
by Caretaker
They do and all three of mine have, but as Pat Goss and the Car Guys told me, its within specs.. There are tons of videos on youtube showing the issues with the poorly designed oil rings which get clogged up and the oil return holes which are too small and too few. That aside, the longevity of this proven Corolla engine used in a multitude of vehicles and trucks around the world demonstrates why it has been such a workhorse all these years. That aside, now that it is 2020, the engine is very much "long in the tooth" and pairs only so-so with automatic transmissions. Toyota and Subaru have a tendency to stick to what works for too long a time (the 1.8 and the 2.0 for example), and get passed up by the Mazdas and Koreans who seem to benefit from those who endorse slow change.
Posted: Wed Dec 16, 2020 5:39 pm
by smash
Thanks for the replies. The oil level was last checked about 6 months before, and had last been changed 1 year (~5000 miles) before . Coolant looks fine.
I recorded the engine sound at idle from within the cabin & have uploaded it. https://imgur.com/BlsVNix.
I'm in Charleston, SC so we don't worry so much about freezing temps, but we usually have plenty of humidity...
I won't have a chance to try to pin down where the sound is coming from exactly before the weekend.
Posted: Thu Dec 17, 2020 4:29 am
by Caretaker
I believe there to be a boatload (not scientific) of heat shields on these cars. It is possible one of them has become loose. The one atop my Fit's manifold had a poorly designed bolt which allowed for separation and rust over time. I had to jam a "C" clip under the bolt head to get the vibration noise to stop
Posted: Thu Dec 17, 2020 7:13 am
by zbyers
That video to me does sound kinda like a heat shield. How does it sound at the front of the car vs. middle vs. rear? What about if you lay on the ground near front/back and listen.
Posted: Thu Dec 17, 2020 4:24 pm
by smash
Loose heat shield vs something engine related makes sense as my power/mpg haven't suffered. I'll try to track it down during daylight this weekend. Thanks!
Posted: Sat Dec 19, 2020 9:48 am
by smash
Rattle seems to be coming from the alternator or close by.
https://imgur.com/a/ZHyNkqx
Given that I've only done tires, brakes, battery & headlamps in 11 years, I guess I can invest a little more to keep it going...
Posted: Sat Dec 19, 2020 11:43 am
by Caretaker
that was an excellent video/audio. Now you may have to focus on the noise being the belt tensioner or the water pump. I had a noisy water pump on mine 6 years ago. My mechanic thought I was nuts. I made him take it off. Once you spun the wheel, the grinding noise was obvious.
Posted: Mon Dec 21, 2020 5:41 am
by SSizler
Sounds like the belt tensioner.
I was able to use a long screwdriver and pry against the tensioner while the engine was runnung, and the noise ended.
I replaced the belt at the same time.
They recommend also replacing the idler pulley, but I did not do that.
Posted: Sat Jan 02, 2021 10:46 am
by smash
Just to wrap this thread up - it was bad bearings on the alternator allowing the pulley to vibrate. Replaced alternator & belt and sounds brand new. :)
Posted: Sat Jan 02, 2021 12:45 pm
by Caretaker
Great work smash. Thanks for letting us know.
Posted: Sun Jan 03, 2021 3:00 am
by jolt
It was most likely the pulley clutch bearing on the alternator that was bad.
https://www.rockauto.com/en/moreinfo.ph ... 94&jsn=846
https://www.rockauto.com/en/catalog/pon ... ulley,2448
A lot of people change out the whole alternator but these pulley clutch and the bearing in the pulley go bad. Chrysler mini vans have these go if you get noise from the alternator / belt area. Most people do not realize that it is not just a pulley but a clutch and bearing in the pulley.
