what to plug throttle body coolant lines with?
Posted: Thu Nov 12, 2020 9:25 am
by thejas
Can someone tell me what I should use to plug up the coolant lines to prevent leaking when removing throttle body\ iacv for cleaning? Is this a specific mechanics tool that's called something?
Re: what to plug throttle body coolant lines with?
Posted: Thu Nov 12, 2020 11:00 am
by zbyers
There are hose pinch-off pliers that would work. Alternatively, the mounting bolts for the throttle body fit perfectly in the hose and stop it from leaking.
https://www.amazon.com/8milelake-3pcs-L ... 5977&psc=1
Posted: Thu Nov 12, 2020 11:41 am
by thejas
zbyers wrote: Thu Nov 12, 2020 11:00 am There are hose pinch-off pliers that would work. Alternatively, the mounting bolts for the throttle body fit perfectly in the hose and stop it from leaking.
Great advice! Thanks! Also, when you lose some coolant from doing this, doesn't air get in the line? How do I bleed that?
Posted: Thu Nov 12, 2020 12:27 pm
thejas wrote: Thu Nov 12, 2020 11:41 amwhen you lose some coolant from doing this, doesn't air get in the line? How do I bleed that?
any air that gets in should work its way through the system and end up at the top of the radiator, and then theoretically that air would be replaced automatically from the coolant reservoir over various heat up and cool down cycles. No need to bleed.
much better than the advice I was going to give, which would have been something like an appropriately sized pencil ;)
Posted: Thu Nov 12, 2020 12:56 pm
by thejas
joatmon wrote: Thu Nov 12, 2020 12:27 pm
Thanks all!
Posted: Thu Nov 12, 2020 12:59 pm
by thejas
Can I use the Toyota matrix valve cover gasket? Part number: 11213-0D040
Posted: Thu Nov 12, 2020 1:06 pm
by thejas
Also, for those interested. Check this out! Lisle 22850 Hose Pincher https://smile.amazon.com/dp/B0002NYB78/ ... UTF8&psc=1
Posted: Thu Nov 12, 2020 2:08 pm
by ColonelPanic
First time I cleaned the throttle body, I didn't even use anything. Just angled the lines upward and kept a towel nearby.
Cleaned it again last week and jammed a vacuum line cap I had laying around into each hose. Got the caps at AutoZone, I think these were what I bought.
Posted: Fri Nov 13, 2020 3:07 am
by thejas
ColonelPanic wrote: Thu Nov 12, 2020 2:08 pm First time I cleaned the throttle body, I didn't even use anything. Just angled the lines upward and kept a towel nearby.
Thanks for the advice! I'm thinking I'm going to clean the iacv while I'm at it. Maybe replace those garbage star screws with hex head bolts.
