Door stops and rust musings
Posted: Wed Oct 07, 2020 8:00 am
Vibe was driven for a while (not me) with no drivers door stop, both the door lower hinge bolt point (severely) and the body where the upper hinge mounts (not too bad) cracked.
Turns out those door stops are important.
Took fender and door off to MIG weld the cracks (turned out pretty good), the rust part is noting the absolute failure of the body panels and plastic guards and such to prevent dirt and muck from accumulating just behind the front wheel-well, an impressive amount of schmutz was behind there.
Also the replacement door stop was wrong, when the door was closed the stop hit the window slightly (if lowered), if you tried to lower the window all the way with the door shut it hit the stop. Maybe they sent the wrong side?
Anyway being a cheap SOB I removed the pin, flipped the stop arm over, and repinned it.
