Engine faltering under load
Posted: Mon Oct 05, 2020 1:40 pm
by maggarjt
2005 vibe with 135k on it
Replaced
IM gasket
Throttle body gasket
Coils, motor mounts
Mass air flow
Pcv valve
Vvt-i solenoid
Transmission fluid
All motor mounts
When I run the car hard uphill or at speeds over 70 the car seems to hesitate. This is my first Toyota having many Honda’s with excellent valve timing and I’m wondering if my vvt is t engaging? What is the rpm switchover for a base vibe 1.8?
Re: Engine faltering under load
Posted: Mon Oct 05, 2020 1:42 pm
by maggarjt
I just wanted to add the car runs great and gets 33mpg consistently Super reliable just odd idle quirks (mostly fixed) and hesitation under load and higher rpm. I suspect it’s a fuel issue but not sure.
What do you think?
