Is there a step by step for adjusting valve clearances
Posted: Sat Aug 01, 2020 8:57 pm
by radioarno
04 vibe, new to me. I have a check engine light that hopefully will be fixed by me replacing the fuel filler neck and the purge valve solenoid on the canister. But I want to do my valves, and wonder why I'm not finding any discussions on here about doing the valves. Its a first gen so the valves need adjusting. I need to know specs and at least a good diagram of where the intake and exhaust valves are and how to open up the top to get to them, etc.
Re: Is there a step by step for adjusting valve clearances
Posted: Sun Aug 02, 2020 2:24 am
One thread about it from a while ago is viewtopic.php?f=20&t=6478 be sure to check out Derf's excellent video on page 2 of that thread
It's a lot easier to check the valve clearances than it is to adjust them. Adjusting requires installing shims, which you have to measure the clearances first in order to know what thickness shims you might need to order. Assuming your 04 is a base, and not a GT, I attached the section from the toyota matrix manual on valve clearance adjustment
Posted: Mon Aug 03, 2020 4:30 am
by zbyers
I honestly don't know of many who have adjusted them. Most leave well enough alone if the vehicle is in good working order.
Posted: Mon Aug 03, 2020 4:47 am
Hmmmm .... just looked over the PDF document showing the lifter adjustment and I would highly recommend NOT doing it at all! As an average backyard mechanic, I wouldn't even attempt this unless the engine was already tore apart. You're asking for trouble. I would suggest a simple test that could determine if the valve clearances are indeed "way off". Perform a simple compression check and if all cylinders look close to normal, then your valves should still be within specs, or close enough to where it is letting in/out enough air. Are you experiencing engine issues with air starvation or suffocation? What leads you to believe that the valve clearances are off?
Posted: Mon Aug 03, 2020 6:52 am
by Caretaker
I concur. I have been told by numerous mechanics that our VVTi valves are NOT adjustable.
Posted: Mon Aug 03, 2020 11:31 am
by andrewclaus
I once had a Honda engine where valve check and adjustment was important, but never on a Toyota engine.
By the way, based on my experience with Honda, if the engine loses compression, it's too late. An experienced mechanic with a good ear can listen to the valve train and get some warning.
Posted: Thu Aug 06, 2020 7:51 pm
by radioarno
thanks everyone. I used to do the valves on my honda fit, and made it sing like a fiddle. But if the vibe valves are not adjustable, I'll just leave well enough alone.
