Replace Fuel filler neck 04 vibe
Posted: Sun Jul 26, 2020 11:29 am
by radioarno
hi is there a step by step to replace the fuel filler neck? Or can someone just tell me what it involves and how difficult it is. Mine is rusty and throwing an evap code
Re: Replace Fuel filler neck 04 vibe
Posted: Sun Jul 26, 2020 4:28 pm
Can' really help on the repair here BUT curious as to the code you're getting. Is is P0441 or P0442? That's what my 04 Vibe GT is throwing and haven't had time to thoroughly investigate it.
Posted: Mon Jul 27, 2020 2:29 am
by zbyers
What are the codes that are being thrown?
In most cases if it's P0442, that is usually the purge valve solenoid located on the charcoal canister under the car.
Tpollauf, not sure if the GT has this purge valve... I have not messed with it on either of mine, yet.
Posted: Mon Jul 27, 2020 4:45 pm
by radioarno
I didn't get the codes, the mechanic got Evap code, and then did smoke test and said the valve on the canister is stuck, and there's a leak from rust on the fuel filler neck.
