Dash Lights go Out when in Park
Posted: Fri Jun 12, 2020 1:16 pm
by copterpilot
Does anyone know what might cause the dash lights to go off when shifted to park? I have replaced the Ignition switch and ignition key cylinder to no effect. It's a base model 2005 Vibe.
Re: Dash Lights go Out when in Park
Posted: Fri Jun 12, 2020 1:29 pm
by Caretaker
Have you tried turning the dash light "knob" which I believe in the first gen is also the roller switch to the left of your steering wheel above the storage compartment? Most cars have it in the speedometer/tacometer display as a multi function button for resetting (by pushing) the mileage counter. My guess is that your roller switch got turned down after someone cleaned the dash with armorall
Posted: Fri Jun 12, 2020 2:31 pm
by copterpilot
Thanks for the suggestion. I did check that and it is fine. The lights work in every gear except in Park. They shut off for some reason.
Posted: Fri Jun 12, 2020 3:06 pm
Welcome to genvibe
Is it just the lights in the instrument cluster or is it all the lights in the dash?
Can you tell if your tail lights go out when the dash lights go out?
Posted: Fri Jun 12, 2020 6:33 pm
by andrewclaus
There is a lamp in the shift console. That's the only connection I can see between shifting and illumination. Perhaps when the shift lever is placed in park, the circuit is opened. I'd look for a loose connection inside the shift console.
As mentioned above, it might help to know specifically which "dash lights" don't work, as well as any exterior lights. What about map lights, dome lights, etc.
Posted: Sun Jun 14, 2020 5:21 pm
by copterpilot
The headlights, dome lights, radio, A/C light all work. Seems to be just the instrument lights. I will check the taillights tomorrow and post the results.
Posted: Mon Jun 15, 2020 5:30 pm
by copterpilot
The taillights work, but now the engine shuts off when shifted to Park! This is the weirdest problem I have seen in a car!
Posted: Tue Jun 16, 2020 4:06 am
by zbyers
Is the check engine light on? If so, what are the codes?
Posted: Tue Jun 16, 2020 4:12 am
by andrewclaus
I'd suspect the shift lever position switch. It has inputs to the ECM. If it tests out, I'd then suspect the ECM. It's on the front of the transaxle, toward the left side of the car. It looks like it's Toyota part number 84540-48010, but check with your VIN to be sure.
That switch also controls the back up lights. Do those work?
Posted: Tue Jun 16, 2020 5:29 am
by copterpilot
No CEL unfortunately as that would help pinpoint potential problems. No codes either. I'll check the backup lights.
Posted: Sat Sep 26, 2020 11:01 pm
by Floridavibes
Did you check the main battery ground wire? I had a slightly similar problem with mine because the ground wire had shorted out. It would occasionally lose ground at one the other and or both.
