2004 AWD Exhaust Manifold needed
rickiann
Post by rickiann »
Anyone know where I can purchase a Exhaust Manifold for my 2004 AWD base vibe? Heard they stopped making them. Plenty around for FWD vibes. Email me rickiannitelli@hotmail.com
Thanks
Re: 2004 AWD Exhaust Manifold needed
Did you check car-part.com ? I see some on there. Don't know where you are but if there isn't one local, you can have one shipped, or work some deal with a local junkyard to get it for you.
Agreed with using car-part.com.
Even eBay has one.
https://www.ebay.com/i/122531534541?chn ... gLm_PD_BwE
rickiann
Post by rickiann »
Zbyers,
Thanks for the reply. They have it for my car, but they just replaced the gasket and it seems to work for now.
Rick
Aflegeal
Post by Aflegeal »
My mechanic says both converters are dead on my 2005 AWD.
( https://www.ebay.com/itm/Manifold-conve ... SwZ4dZMwNt)
(https://www.ebay.com/itm/Fits-Toyota-Ma ... SwVtZaPS1r )
I showed him these ebay links and he says he is uncertain if the manifold one will work since the description only says it fits an AWD Matrix.
Has anyone actually purchased this and put it on their Vibe?
Or is anyone 100% confident that it will fit an AWD Vibe if it describes it as fitting an AWD Matrix?
And last question; does anyone have a link for the gaskets that would be needed for replacing both converters? Between the manifold and first converter and between the first converter and pipe to the second converter?
Thanks for your help!
Same year drive train (04 AWD Matrix/Vibe) would be interchangeable.
The mechanic should be able to procure the gaskets too.
