Clutch Question
Posted: Wed May 06, 2020 6:45 am
by JerryV
I am getting my 09 GT back together and have a question about the clutch. There doesn't appear to be any spring there to retract the fork and throwout bearing from the pressure plate. I am wondering if there is supposed to be one and how it connects.
Thanks,
Jerry
Re: Clutch Question
Posted: Wed May 06, 2020 7:38 am
by zbyers
I'm not 100% positive on the second gen, but I do not believe there is an actual spring to do so.
Re: Clutch Question
Posted: Thu May 07, 2020 5:15 am
by JerryV
I haven't seen anything about it in the service info I have either, but it seems like there should be something to keep the throwout bearing off the pressure plate so the bearing isn't spinning all the time. I haven't worked on a clutch for a long time, but every other one I've seen is that way.
Jerry
Re: Clutch Question
Posted: Thu May 07, 2020 5:36 am
by zbyers
I would presume that's the objective of the clutch fork too. I don't recollect any spring when I swapped the clutch of my 03.
You could try calling the Toyota dealer and inquiring about a Matrix or Corolla of the same year.
Re: Clutch Question
Posted: Thu May 07, 2020 11:55 am
zbyers wrote: ↑Thu May 07, 2020 5:36 am I would presume that's the objective of the clutch fork too. I don't recollect any spring when I swapped the clutch of my 03.
I don't remember any such spring on my 03 either. Is it possible the rubber fork boot is stiff enough to do the job without a spring?
Re: Clutch Question
Posted: Fri May 08, 2020 6:18 am
by zbyers
joatmon wrote: ↑Thu May 07, 2020 11:55 am
That's logical. Here is a write up on doing it, but I follow a slightly different procedure than this. I don't see anything about a spring.
http://wehavescissors.blogspot.com/2009 ... be-or.html
