What other OEM stereos fit?
Posted: Thu Apr 23, 2020 10:38 pm
by theblurb
Say I wanted to swap out my 2007 Vibe factory stereo with another unit with, ahem, functioning lights. Might another better Toyota or Pontiac stereo of similar vintage fit right in?
Re: What other OEM stereos fit?
Posted: Thu Apr 23, 2020 11:39 pm
by SlammedNiss
Pretty much anything that is 1.5 DIN will fit. You'd have to get a different harness though to adapt to the existing wiring.
Posted: Fri Apr 24, 2020 3:07 am
by zbyers
For a direct swap, including p-n-p of wires, without an adapter, you're stuck with 03-08 Vibe, and 03-04 Matrix.
However, you can buy cheap double din roads, or even single dins, that have much better features and functional lights. A cheap headunit with bluetooth, aux, USB, can be had for like $50. The wiring adapter is probably $10, and the dash kit is probably $20. For less than $100, you could have a hell of a lot better of a unit.
Posted: Fri Apr 24, 2020 6:04 am
Yeah I too will be looking into an aftermarket unit soon. Bulbs are starting to go out "intermittently" and a few of the most common buttons are worn to where you don't know what they are anymore. Plus I really want one with a backup camera. Mid-summer/late fall project for the 2004 Vibe GT ;)
Posted: Fri Apr 24, 2020 7:09 am
theblurb wrote: ↑Thu Apr 23, 2020 10:38 pm Might another better Toyota or Pontiac stereo of similar vintage fit right in?
GM of the era offered a number of radios that looked the same as the ones in the Vibe, however, there are internal differences. The Vibe was unique, all the others used a "data bus" that tied the radio to the computer, which provided an anti-theft "feature" requiring the radio to match the vehicle VIN somehow. If you get a radio that looks similar from a Chevy, it will be locked out in your vibe.
Its not that hard to replace the burned out lights
