2ZZGE Valve stuck Open
Posted: Tue Apr 07, 2020 7:46 am
by ReedWolf
Hey so on my 2003 Pontiac Vibe GT my lift stopped working and the OBD2 scanner said Valve stuck open, What could be causing it to stay open? Do I have to get the head replaced or the valve or what? I've had the car for awhile it was sitting till September 2019 then I started driving it, Thanks in advance!
Re: 2ZZGE Valve stuck Open
Posted: Wed Apr 08, 2020 2:32 am
by zbyers
What is the actual code that you have?
Posted: Wed Apr 08, 2020 4:29 am
online I found two OBD codes with the term "valve stuck open"
The first is P2070, Intake Manifold Tuning (IMT) Valve Stuck Open Bank 1 but I can't find anything in my service manuals for that one
The second is P2440, Secondary Air Injection System Switching Valve Stuck Open Bank 1. I attached the 03 Matrix manual doc for that code. Since that doc refers to the wiring diagram in the write up for P2430, I also attached that doc
If its P2440, then that's good news, an air switching valve outside the engine is a lot easier to service than an actual intake or exhaust valve inside the engine
and ReedWolf, since that's your first post here, Welcome to genvibe!
Posted: Wed Apr 08, 2020 6:34 am
by ReedWolf
Hi thanks for the warm welcome!
I got the OBD test done at autozone they only told me the code was "P1693 Valve stuck open"
As you can see neither of the codes you stated, i then looked for a receipt i got from getting my Vibes misfire fixed and it stated "P1693 Rocker Arm Actuator System"
im gonna look up what could be causing this fault and how i can get it fixed!
Thanks!
Posted: Wed Apr 08, 2020 9:04 am
by andrewclaus
That code is for the Variable Valve Lift system. The valve may be this part number: 15330-28020 Check with your VIN to be sure.
Posted: Wed Apr 08, 2020 11:02 am
I attached the matrix manual section for P1692 (OCV for VVTL Open Malfunction) P1693 (OCV for VVTL Close Malfunction) and also the one for P1690 since it's referenced by the 1692/1693 one.
Hopefully its just the filter in step 3 of the 1692/3 doc needs to be cleaned. That solved 1693 for whitealltrac at viewtopic.php?f=11&t=44163&p=503929#p503929
also see lobi's pics in viewtopic.php?f=12&t=44005
Posted: Wed Apr 08, 2020 6:10 pm
by ReedWolf
Thanks so much for the help, ill be getting it fixed when i can leave the house, Dont wanna risk it with everything going on right now. ill let you all know when its fixed! thanks!
