You mean they don't want to do the work, so they're quoting high? Not sure what you are saying.
precisely.FatherTime wrote: ↑Thu Mar 12, 2020 6:38 amYou mean they don't want to do the work, so they're quoting high? Not sure what you are saying.
Pep Boys?FatherTime wrote: ↑Thu Mar 12, 2020 5:03 am Well thanks for the feedback. I'm getting a bit suspect about this one particular auto shop. Every time I get an estimate there they include work that is not necessary, misquote from the service manual such as "your way overdue for spark plug service" (when it's not due for another 10k miles), or quote ridiculous prices like $450 to change 4 spark plugs. When I asked why it's so high he blathered something about access to the plugs. Being curious, when I got home I popped the cover off the engine for the first time and yeah, there is no access issue. Scary thing is, they have a fairly busy shop, which makes me wonder how many people are being taken advantage of.
So, I shouldn't bother getting a 4 wheel alignment, is what you're saying?zbyers wrote: ↑Thu Mar 12, 2020 5:29 am The book for a first gen vibe calls for an hour on spark plugs. Second gen won't be much different, so $450 is overkill.
That could just be their "I don't wanna do this quote." Same thing with adding in an alignment on rear struts, especially since you can't align the rear end.
If you have a FWD, you wouldn't actually be getting a 4 wheel alignment. The only way you can really align the rear if it is out of spec, is to shim it. However, they will still likely attach the machine to the rear wheels to make sure it isn't messed up.Bookworm wrote: ↑Thu Mar 12, 2020 10:22 amSo, I shouldn't bother getting a 4 wheel alignment, is what you're saying?zbyers wrote: ↑Thu Mar 12, 2020 5:29 am The book for a first gen vibe calls for an hour on spark plugs. Second gen won't be much different, so $450 is overkill.
Why isn't that listed in the manual?
That's kind of the experience my father had with Pep Boys the first (and only) time he took a car there. He's a mechanical engineer, and up until recently, always did his own car repairs (unless tools would be an issue). He went in for a single problem, and the local Pep Boys pulled a "Oh, yeah, you need X, and Y, and Q, and P, and R, and then your original problem will cost H. "FatherTime wrote: ↑Thu Mar 12, 2020 4:42 pmThing is, the guy spent at least 10 minutes on the computer whipping up a list of things he felt was necessary to do, prioritizing, and included the prices. I don't think he would do that if he didn't want my business. I think he wanted my wallet.precisely.You mean they don't want to do the work, so they're quoting high? Not sure what you are saying.
On the 03-08 FWD Vibe, there is no adjustment to the rear. Some shops may be willing to shim it, if they can get or have shims. But for the most part, they leave well enough alone.Pauls325 wrote: ↑Thu Mar 19, 2020 2:10 pm If you are doing suspension work its never a bad idea to have the alignment checked, most shops will check alignment for free, they do attach sensors to all four wheels , the rear wheels determine the thrust angle of the car, so basically the front is aligned based on the rear, if the rear is out by a significant margin it can be changed using shims, most shops will charge wheel bearing labor to align the rear. however i have never heard of a shop offer different pricing if only the front needs adjustment.
