Need help on 2003 Vibe AWD rear mount removal
Posted: Sat Jan 11, 2020 3:59 pm
by cmgreyhounds
It seems to be captive between the steering rack and the k-member. I'm just not figuring out how to get the (removed) out of there.
Lots of videos on replacing the mount for a FWD version, but the AWD is quite a bit different. Thanks in advance!
Re: Need help on 2003 Vibe AWD rear mount removal
Posted: Sat Jan 11, 2020 8:19 pm
by cmgreyhounds
Well as it turns out there's no way but the hard way for this one.
You have to unbolt the steering rack and drop the suspension k-member to get the clearance to get the mount out. Also disconnect the sway bar end links first so the sway bar doesn't hold up the k-member.
Not a fun way to spend a Saturday, but there it is.
Posted: Mon Jan 13, 2020 4:34 am
by zbyers
First, welcome to genvibe. Home of the best group on the internet.
That's a bummer that you had to partially drop the front k-frame to get the rear engine mount out.
Are you replacing all of the mounts? Or working on something else?
PS: we like pictures..of your car, dog/cat, or the project your working on with your car.
