2009 AWD Timing Chain to replace or not
Posted: Fri Oct 25, 2019 6:11 am
by blpmich
I have a 09 AWD with 104,000 miles. Runs great and had all the required work and updates done.
Question is it worth having the timing chain replaced? The quotes I've gotten are between $650 and $1400.
Has the timing chain been an issue with 09 or 10 Vibes?
Thank you.
Re: 2009 AWD Timing Chain to replace or not
Posted: Fri Oct 25, 2019 7:28 am
by zbyers
timing chains should last the lifetime of the engine. i'd leave well enough alone. if anything, replacing the timing chain tensioner is a better option as the job of it is to take up any slack the chain may develop.
TBH, we have 6 vibes, all but one are north of 180k miles and none have had the timing chain messed with; just new timing chain tensioners since they are prone to leaking.
Posted: Fri Oct 25, 2019 10:29 am
by jolt
What issue are you having that you believe the timing chain needs to be replaced?
Posted: Sat Oct 26, 2019 8:18 am
by Bookworm
jolt wrote: ↑Fri Oct 25, 2019 10:29 am
Could simply be that you replace timing belts at about that interval for the first one, and the _old_ timing chains (pre 90's) had breaking issues, so required replacement as well. That's why they went to belts. The metallurgy is better now, as well as the tensioners.
Posted: Mon Nov 04, 2019 11:44 am
by jolt
Bookworm wrote: ↑Sat Oct 26, 2019 8:18 am
Timing belts have been around since about 1974 in American made cars and timing chains way before that (mostly link chains). I have never seen a roller timing chain break unless it was cause by other issues like worn out chain guides or poor oil pressure to the chain tensioner because of blockage in the oil passages. Chains do stretch under use but roller chains do not cause as many problems as link chains do with messing to the gear teeth as the chain stretches. Timing belts are your cheapest to manufacture and produce, but also wear out and require far more service then roller chains do. Early engines with timing belts had a major problem that when the belt broke, the pistons would hit the valves and bend the valves. These are called interference engines. Some manufactures re-designed the pistons to prevent this from happening and those engines are called non-interference engine. Most timing belt engines are non-interference engine now. The main reason to use a roller timing chain now, despite the increase in cost to manufacture, is that the engine design is an interference engine. A interference engine provides better efficiency without compromises to the combustion chamber design that a non-interference engine would have for valve clearance when the timing belt breaks. Changes in materials and design have made big improvements for timing belts but the roller chain inside the engine, still will out last a regular timing belt under normal usage.
Still have seen no reply from the OP about why the timing chain. Is the problem this:
