JDM Toyota Voltz Mirrors
Slybee
Post by Slybee »
For sale is a set of power folding mirrors from the Japan market Toyota Voltz. I will include the modified LHD switch panel assembly I did. You will need to run two wires to both doors for the folding function to work, 2 position connector kit, I used a Deutsch DTM kit, and you must cut and solder the plug off your original power mirrors.
Looking for $180 SHIPPED to the US50
Re: JDM Toyota Voltz Mirrors
That's a nice set up. What is the blank on the control panel for?
SeattleJeremy
Post by SeattleJeremy »
zbyers wrote: ↑Tue Aug 27, 2019 9:49 am That's a nice set up. What is the blanket on the control panel for?
The button is to activate the motors that fold them in or out. Fancy stuff for a Vibe.
SeattleJeremy wrote: ↑Tue Aug 27, 2019 1:02 pm
I get the button (pretty picture is pretty self explanatory :lol: )... I meant the blank for the switch.
Bookworm
Post by Bookworm »
zbyers wrote: ↑Wed Aug 28, 2019 2:34 am
For the control on your existing panel. Just look to the left of your steering wheel :)
Bookworm wrote: ↑Thu Aug 29, 2019 7:39 am
duuuh. i didn't even think about that dimmer switch being on that panel. hahaha. makes so much more sense now. :D
atro2020
Post by atro2020 »
Slybee wrote: ↑Fri Aug 23, 2019 10:08 am For sale is a set of power folding mirrors from the Japan market Toyota Voltz. I will include the modified LHD switch panel assembly I did. You will need to run two wires to both doors for the folding function to work, 2 position connector kit, I used a Deutsch DTM kit, and you must cut and solder the plug off your original power mirrors.
I've been wanting a set of these mirrors with the control panel. Have any more of these or a lead where I can get them?
AMC EAGLE SX-4______ DATSUN 280Z
Looks like there's a japanese used auto parts site autoparts.beforward.jp
they list a number of the mirrors
https://autoparts.beforward.jp/search/T ... or-Mirrors
I don't know if they are all electrical folding ones or if some are non-folding. You might be able to pull some part numbers and see if there are lower cost sources
They don't have the control switch in stock, but they show it at https://autoparts.beforward.jp/detail/E ... A33632053/ as Toyota part number 8487201010 which google finds as available from other sources
can't find the plastic switch trim panel though
joatmon wrote: ↑Sun Mar 13, 2022 5:13 pm I don't know if they are all electrical folding ones or if some are non-folding.
Looks like a 5-wire connector so I'd say they are folding mirrors. It would be interesting to see what the original sales brochure says as standard equipment for those mirrors. Maybe they all came with folding mirrors regardless of trim level :?
