				Air flow directional knob light location and replacement..
				Posted: Sun Jul 07, 2019 3:34 am
				by metaxa44
				My air flow directional knob was stuck in defrost position and finally I got it to work, but now the light is out..
Where is the bulb location or how do I replace it?
Thanks
				Re: Air flow directional knob light location and replacement..
				Posted: Sun Jul 07, 2019 5:06 am
				by andrewclaus
				This link shows how to disassemble things. Look in Section 71-10.
https://madstyle1972.com/Repair/71/20ikx/x040001.pdf
				Posted: Tue Jul 09, 2019 3:06 am
				by zbyers
				They suck to remove.
				Posted: Tue Jul 09, 2019 5:53 pm
				by metaxa44
				I toke the top trim of and the radio out hoping I can just reach in and change the bulb , but cannot find it...
				Posted: Wed Jul 10, 2019 2:48 am
				by zbyers
				You will probably need to remove all of the trim around that, including the 12v/110 panel below the HVAC knobs. Not sure if you can reach down inside with the radio removed.
				Posted: Sat Jul 20, 2019 2:40 pm
				by metaxa44
				OK , so I got everything apart and it wasn't too bad.
I got the bulb out too and it's burned out..
What is the correct part number for the bulb ?
Wonder how much are they...
By the way radio doesn't have to be disconnected to do the job...
				Posted: Sun Jul 21, 2019 10:22 am
				by Bookworm
				I don't recall the bulb number - I'm certain another of the forum members will chime in.   I suspect it's the same as the ones for the instrument cluster, so a quick search might help, so you can at least compare .
				Posted: Sun Jul 21, 2019 5:34 pm
				by andrewclaus
				Posted: Sun Jul 21, 2019 7:51 pm
				by metaxa44
				Most likely , except it is yellow ...
Thanks guys...
				Posted: Mon Jul 22, 2019 2:42 am
				by zbyers
				You could buy a neo3 or neo4 bulb from superbrightleds.com to replace it with an LED one.
				Posted: Mon Jul 22, 2019 6:00 am
				by metaxa44
				Ok the job is done ,bulb replaced ..
part # from Toyota 90010-01122 / $ 7..
GM only sells the hole unit and tried to tell me the bulb is hard wired...LOL..
I informed him that is funny because I have the bulb in my hand..
Anyways the local Toyota knew what I am talking about and had it in stock..
Takes 20 minutes to do the job..
Thanks to everyone for the help...
				Posted: Sun Mar 03, 2024 5:31 am
				by JackWade
				Thanks for the part #.
