Everybody knows where this piece came from
Posted: Sat Sep 06, 2003 4:54 am
Found this on the front passenger floor in my Vibe, looks like some kind of nut. Anybody recognize it, know where it's supposed to go?
Re: Anybody know where this piece came from? (silverawd26)
Posted: Sat Sep 06, 2003 5:11 am
quote:Has a slot in it...Did you adjust your A/C cable?I did the adjustment like in http://forums.genvibe.com/zerothread?id=1315, but there was no piece like this to take off when I did it. Looking at KSNeptune's pic in that thread, his didn't have one there either. are you asking about a different AC cable?
Re: Anybody know where this piece came from? (joatmon)
Posted: Sat Sep 06, 2003 5:48 am
by cool vibes
Yes i have found the same nut or screw cover on my floor<if you look were the dead mans pedal you will notice a plastic side cover above this pedal there is a screw sticking out .this nut cover goes over the screw hope this helps
Re: Anybody know where this piece came from? (cool vibes)
Posted: Sat Sep 06, 2003 5:53 am
by scherry2
quote:Yes i have found the same nut or screw cover on my floor<if you look were the dead mans pedal you will notice a plastic side cover above this pedal there is a screw sticking out .this nut cover goes over the screw hope this helpscorrect! I found the same nut when we put the blinkers on raging's vibe. but that goes on the passenger side over a bolt sticking out.
Re: Anybody know where this piece came from? (rasermon)
Posted: Sat Sep 06, 2003 6:11 am
by scherry2
quote:It's tool used to get shift out of park (P). Automatic Transaxle Only. You will find more info. in your manual on page 2-32 really?
Posted: Sat Sep 06, 2003 6:51 am
<BLOCKQUOTE>quote:<HR>It's tool used to get shift out of park (P). Automatic Transaxle Only. You will find more info. in your manual on page 2-32 <HR></BLOCKQUOTE>Rasermon, did you know the word gullible isn't in the dicitonary? ----------------------------------------------------------coolvibes, scherry2 thanks, I'll look around for a naked screw. ****
Re: Anybody know where this piece came from? (scherry2)
Posted: Sat Sep 06, 2003 7:36 am
by ragingfish
quote:Yes i have found the same nut or screw cover on my floor<if you look were the dead mans pedal you will notice a plastic side cover above this pedal there is a screw sticking out .this nut cover goes over the screw hope this helpscorrect! I found the same nut when we put the blinkers on raging's vibe. but that goes on the passenger side over a bolt sticking out.Yesh. It's what I call a "plastic nut." It just pushes on over a screw and locks into place. Then you unscrew it normally. They are found in the foot areas of the dash...there is one by the dead pedal, and another by the passenger side door. I'll snap a pic later.
Posted: Sat Sep 06, 2003 7:53 am
I looked at my car, and see where they are used on both sides to hold a trim panel on. One on each side. Unfortunately I only found the one, because both were missing. I put it on the driver's side. Thanks
Posted: Sat Sep 06, 2003 8:57 am
by ragingfish
For those who still can't figure out where they go, I come bearing pictures!Driver side: Passenger side: On this side, just stick your head down and look for where the carpet ends up in the dash...best way I can think to give you a point of reference...
Re: Anybody know where this piece came from? (ragingfish)
Posted: Sat Sep 06, 2003 9:53 am
by msmyer
Mike-Remember that was my part in taking that out to "help" install the mirrors! LoL
Re: Everybody knows where this piece came from (joatmon)
Posted: Sat Sep 06, 2003 9:00 pm
by retiredfields
They don't stay on very well. I put a small piece of thin foam with sticky backing over the screw first, then pushed on the plastic nut. Now it stays in place.
Posted: Sun Sep 07, 2003 12:20 am
by scherry2
quote:Rasermon, did you know the word gullible isn't in the dicitonary? Wow I thought my alzheimers was kicking in again.
Re: Anybody know where this piece came from? (msmyer)
Posted: Sun Sep 07, 2003 12:55 am
by ragingfish
quote:Mike-Remember that was my part in taking that out to "help" install the mirrors! LoL Yesh!How could we forget!
Posted: Sat Apr 03, 2004 1:18 am
OK new contestToday I was checking my cabin air filter, and when I removed the glove compartment, I heard a mettalic rattle. Looked in and just to the left of the glove comartment opening, I found a loose piece of metal, first glance I thougt it was a box end wrench, but pretty obvious it is some sort of structural brace from somewhere in the dash. I had heard a mettalic rattle for some time, hope this is what was causing that, but not sure if I should just leave it out or try to put it back. Don't want to have to disassemble the whole dashSo what is this thing, and is it important?attachment same as image above, in case I lose web host later
Posted: Sat Apr 03, 2004 3:38 am
by russ257
that looks like a go to the dealer and go what the hell why is my car falling apart amd make them fix it piece
Re: Anybody know where this piece came from? (russ257)
Posted: Sat Apr 03, 2004 5:43 am
Quote, originally posted by russ257 »that looks like a go to the dealer and go what the hell why is my car falling apart amd make them fix it piecethat's what I would do if it wasn't for http://forums.genvibe.com/zerothread?id=8147
Posted: Sat Apr 03, 2004 7:31 am
by rasermon
Joatmon, believe I found it!
Posted: Sat Apr 03, 2004 8:28 am
I'm sure that's it. Now I just have to decide if I want to hurt myself getting it back in there. It's one thing to see it, it's another to get my hands up in there to put it back, if I can find the nuts to screw it back on. Thanks for going to the trouble to look for it. It is a bit unsettling to have what appear to be structural pieces falling off
