Reverse Circuit - backup camera
Posted: Tue Apr 09, 2019 9:56 am
I am trying to install a new blue tooth/gps/radio on my 06 Vibe. I found this link
viewtopic.php?f=18&t=43639&p=499239&hil ... se#p498943
and it was very helpful.
But I can't find where to plug into the reverse circuit??
and take a tap from the backup light lead (between the light and the fuse block)
I THINK I have found the wire, a red with blue strip, but when I test it, the radio still does not come on to camera when sifting into reverse (works otherwise).
I called Bose, and they said I was right about what to plug in, but they said it should be a red cable with a black strip. I have double checked, and it is NOT faded, definitely blue strip. Could I have the wrong cable, even though I am looking at the right one coming right out of the reverse light?
Long story short, I just need to plug into the reverse circuit, preferably under the dash, but I would accept anywhere.
I love pictures if you have some.
P.S. I am using a 14 gauge cable as my testing cable, is the fact it is large causing problems?? I would not think so, and i would rather not go out and buy more cable I don't need it i don't have to.
