'09 Clutch Part Questions
Posted: Wed Mar 06, 2019 6:53 am
Hi Everyone. I'm new to GenVibe posting, although I have been an avid reader over the years of these forums.
I have an '09 2.4L FWD Vibe, which believe it or not, is now going on 10yrs/240K km, and my Clutch just died. I'm not complaining toooo much as this is my first major mechanical issue in this time. Thanks to all the previous posts and conversations about replacing the Clutch I've decided to go DIY as overall this mainly seems to need Time and Patients. And I would like to get a few more years from this Vibe. Also, my Dealer-Shop is asking $4-5K for their labor and over priced parts. This is the clutch and a couple other items (Sway Bar Links). Based on the postings on GenVibe I found RockAuto to be the best for pricing and also delivery time. Which means I can price this replacement out at under $1K (which includes the charge of being towed home).
What I need help with is specific to the Flywheel. Most postings deal with pre-'09 GT engines, or the 1.8L version, and do include parts, but not many post were found for the '09 2.4L. Based on what I have been able to figure out the 1.8L Flywheel is ofcourse different from the 2.4L, so I did not order the 1.8L version. RockAuto does not have this part listed for the 2.4L so I have a few questions I'm hoping you other Vibe owners may be able to clarify for me.
- RockAuto does have a Flywheel under the '09 2.4L Matrix [LUK LFW245]
-- Visually this 'looks' the same as what my Vibe would use, but is this OK?
- Comparing on RockAuto the Flywheel for the 1.8L engine of the Matrix and 1.8L Vibe, those are the same part # and look the same [AMS AUTOMOTIVE 167154], which leads me to believe that YES I can use that one listed for the 2.4L Matrix on my Vibe.
- OR other brand suggestions? Part #'s? I did check the GM Parts suppliers and other sites, but most do not seem to have a Flywheel for the 2.4L engine, or are asking $270+, even Napa did not have a match, and an Auto-Wrecker I also called wanted 2x RockAuto's price.
- also to clarify ... are the Matrix engine parts OK for the Vibe? Are these actually the same/interchangeable? Maybe just different part #s due to the Brand difference. Asking this for future ref as I suspect other Vibe parts may be hard to find, but may be findable via the Matrix.
All that being said, I've picked the Luk Clutch kit, which seems to have good reviews, and will also replace the Oil seals, Slave Cylinder, and any other parts you might recommend that I consider? And just in case you're wondering, why not resurface the Flywheel? Well, if it is damaged/burned, then having the new one I will not have to wait more to order/deliver or even to run-around to have it resurfaced - if it is OK. But having the new on hand one means no extra waiting.
Sorry for the long post and Thank You to any feedback or advice both for these parts and of the Job itself.
