Cleaning the gauge cluster?
Posted: Thu Sep 04, 2003 11:30 am
by Toasted7
What do you use and how do you clean the faces on the guage cluster? (ie. speedometer, tach, etc.)
Re: Cleaning the gauge cluster? (Toasted7)
Posted: Thu Sep 04, 2003 12:01 pm
by ragingfish
I just use glass cleaner, but I'm looking to get Mother's Plastic Polish which supposedly is much better for the purpose...
Re: Cleaning the gauge cluster? (ragingfish)
Posted: Thu Sep 04, 2003 2:20 pm
by engine1
And get one of those micro fibre cloths, I tried diapers, cheese cloth, that soft polishing cloth GM gives you. Every one left scratches! And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!
Re: Cleaning the gauge cluster? (engine1)
Posted: Thu Sep 04, 2003 2:40 pm
by ragingfish
quote:And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!Yep...always do!
Posted: Thu Sep 04, 2003 2:48 pm
by Toasted7
quote:And pull the facia off its so much easier to clean then you don't get that little dust halo around the edge of each guage!Yep...always do!Do wha? Please tell... how do I get the guage cluster facia off to clean behind it? Details, cause I don't want to break anything.
Posted: Thu Sep 04, 2003 2:51 pm
by ragingfish
Quite simple. Just lower the steering wheel all the way, grasp the circles on each end, and pull forward. Comes right off. Then, to put it back on, just make sure you thread the odometer button through, and push back until it snaps in place!
Posted: Thu Sep 04, 2003 3:09 pm
by Toasted7
That easy? The whole cluster comes off, not just the chrome right? If it is really that simple, that will make cleaning a whole lot easier. Now if I could just figure out what to use that won't leave scratches, then I will be in business.
by ragingfish
Yeah, whole ringset comes off...I'm gonna track down that plastic polish and let you know how it works out...
Posted: Thu Sep 04, 2003 3:12 pm
by Toasted7
Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.
Posted: Thu Sep 04, 2003 3:22 pm
by ragingfish
Just ordered Mothers Plastic Polish online...should have next week sometime...will let y'all know how it works out. It's supposed to be good for both the gauge cluster as well as the headlight lenses...Also ordered Mothers California Gold Touch Up Kit, which you use in conjunction with touch-up paint, and supposedly does wonders to fill in scratches...will also let y'all know how that one works out...
Posted: Thu Sep 04, 2003 7:58 pm
by NSimkins
quote:Let me know when you find it and how it works... as for me, I'm going to try to get that cluster panel off, just to see if it is really that easy to remove.I have pictures of the gauge rings removed in this older thread. That should help you get an idea on how to remove.http://forums.genvibe.com/zerothread?id=396
Re: Cleaning the gauge cluster? (NSimkins)
Posted: Fri Sep 05, 2003 6:56 am
by meathead333
i cleaned it once real well with glass cleaner. now i just a swifter duster, it picks up all the dust and stuff real well.
Posted: Mon Sep 08, 2003 8:07 am
by ragingfish
Posted: Mon Sep 08, 2003 9:29 am
by champcaracing
pull the bezal off, then use 3m hand glaze, works great!!!!
Re: Cleaning the gauge cluster? (champcaracing)
Posted: Mon Sep 08, 2003 10:52 pm
by Stang2Vibe
I suggest just wiping it clean with a lens cloth. I have one made by 3M that I use on my glasses. I got to thinking one day while cleaning the car and found that it works well. Everything else scratches the plastic. And a big thank-you to those who discovered how to pull the gauge cluster apart, it will make cleaning a whole lot easier! Now if only I can find some white faced aftermarket gauges...
