Trailering a 2006 Vibe
Posted: Mon Oct 29, 2018 5:20 am
Wasn't sure where to post this. I am going to pick up our second Vibe later today and bring it home on a trailer. I haven't much experience trailering. The plan is to have two straps up front and two out back, crossing them. I see what seems to be designed for such a thing in the front end....at either end of the rad cradle hang down a "tab" that a hook would fit into nicely. Is this an adequate spot to secure the front end?
As for the rear. I can't seem to see a place that would be secure. The hole in the rear tube isn't large enough for the hook on the strap?
I just had another look......how about the bottom bracket where the shock mounts. Seems quite robust there. I can have the hook go up into that bracket and cross it to the other side of the trailer?
Any help would be greatly appreciated. Thank you in advance
Paul
Paul
