2007-specific transmission pan gasket & filter
Posted: Thu Oct 11, 2018 5:05 am
Hi all - planning a drain-refill-drive-drain- pan drop-refill of my transmission fluid in the next couple of weeks. I've looked around for info on the correct pan gasket, filter (if any) and plug washer (if any) and can't find 2007-specific info. Anyone out there done this on a 2007 base model know or remember if this is the proper gasket (ebay vehicle look-up says yes for 2007 Matrix, but no for 2007 vibe - it's also the same gasket referenced in a thread, I'm guessing for a '03, here: viewtopic.php?t=29717).
https://www.ebay.com/itm/TOYOTA-OEM-Aut ... #vi-ilComp
I also ran across mention of a crush gasket for the transmission drain bolt for an '04 here: viewtopic.php?t=43942
I'm assuming most parts were the same 03-08, but not positive, so if anyone has direct info on the 2007 model, that would be greatly appreciated.
Thanks!
Thanks!
