Weird auto trans problem
Posted: Fri Jul 27, 2018 2:34 pm
2006 Vibe base. All foward gears work perfect in D no slippage no binding. When in neutral the car is still in drive but doesnt seem fully engaged. In reverse i got nothing. When i rev it in reverse the egnige goes to 2000rpm. No signs of movement or transmision load but it hits the stall speed of the tourqe converter. If i slowly try to hunt for reverse as i get closer to park the car starts to go into a forward gear and then you can hear it start to hit the park detent pin. When the car is in park and i try to rev the engine it goes to 2000rpm. I have adjusted the cable but it still does what i described. Any thoughts? I read its common for the valves in the valvebody to stick as well as the valvebody warping from over heating. I dont recall overheaing it and the fluid is still red and no burnt smell.
