Bypass catalytic converter
Posted: Sat May 19, 2018 2:52 am
by crystal79
Muffler shop wanted $600 to repair 03 vibe. Another wanted $100 to bypass it. So, I chose the $100 option, not fully understanding things. Now, trying to sell it, when I say converter has been bypassed customer loses interest. I see there are some on eBay for $125. What to do? I feel i have to tell them. Is it better to just buy the $125? What problems could show up from bypassing it? Thank you in advance..
Re: Bypass catalytic converter
Posted: Sat May 19, 2018 6:42 am
by andrewclaus
I think the CAT you can legally use will depend on if you're in a CARB state. If it has to be labelled to California standards, it's going to be more expensive, maybe double.
I wonder how the shop dealt with the downstream O2 sensor. Do still you have a check engine light after the work?
I've never done this, so I'm not sure, but that's what I've read about other cars.
Posted: Sat May 19, 2018 10:08 am
by jolt
Does your "Check Engine" light work? It should be on if the convertor is removed unless more things are bypassed. I myself would not by many vehicle if the check engine light did not work. Once I see that it is run away time.
Posted: Mon May 21, 2018 4:10 am
by crystal79
Thanks, guys, The check engine light works, but is not ON when driving. Anyway, I just ordered the kit to restore it to previous state.
