Brake help.
Posted: Wed May 09, 2018 5:41 am
by foxmotofan15
So about a year my brakes started to go. I parked it for about six months because the sway bar link decided to go. So I fixed that but from sitting for so long the brakes rusted up. So I started with replacing the rotors and pads all around and the right passenger caliper because I snapped a bolt.that didn't work. I still had very little braking power. Next I went and replaced the master cylinder. that still had no effect. Then I noticed when the car was off when i would press on the brake pedal it would depress, so I thought ok there is a vacuum issue. So next I replaced the power booster and put new clamps on the vacuum houses too make sure they were on there tight because the old clamps weren't holding the hoses tightly. Now with the new power booster I have no pedal at all, with car on or off. I'm waiting on the tool to adjust the push rod inside the booster to see if that was the problem. Past that though I don't know where else to turn. Any suggestions would be appreciated thank you.
Re: Brake help.
Posted: Wed May 09, 2018 7:35 am
Welcome to genvibe
You didn't mention it so I need to ask, did you bleed the air out of the hydraulic lines after the hydraulic component replacements?
Re: Brake help.
Posted: Wed May 09, 2018 8:18 am
by vibrologist
https://www.youtube.com/watch?v=n1NvtUwfRJc
Generally, it is not a good idea to replace hydraulic parts on one side only. It may be OK but internally the older caliper has less internal resistance than the new one which leads to uneven brake force. You may feel this with very light touch to the brake.
I am working on the brakes of a 08 Hyundai Sonata. One thing I noticed is that the areas where the pads are held on the brackets are corroding in significant ways. There is more corrosion than the wire brush can remove. I chipped away a layer of that stuff and used a file to get to solid metal. I put anti-seize stuff on these surfaces before adding the shims. I also took out the slides, cleaned them, cleaned out the bore for them and greased them up with anti-seize.
I suggest you bleed the system again even if you have done it before. In fact I would completely flush the system.
You replaced the master cylinder. Look at this video to see if you have done all the steps.
https://youtu.be/trotrlIG2sk
Which year and how many miles on your Vibe?
Re: Brake help.
Posted: Wed May 09, 2018 12:16 pm
by foxmotofan15
joatmon wrote:Welcome to genvibe
That is what I am in the middle of currently
