Looking for a new rear subframe for 2004 AWD vibe
Posted: Mon Mar 26, 2018 7:03 pm
by BossSpud
I recently bought a 140k jet black 2004 pontiac vibe AWD. I am loving every second of the car. ( this is my first car btw) I have a huge hole in the rear sub frame and I am looking for a possible replacement in the Deleware area. I am willing to drive a little bit if need be.
Re: Looking for a new rear subframe for 2004 AWD vibe
Posted: Thu Mar 29, 2018 3:55 pm
welcome to genvibe
I'm guessing you would probably need to get that from a junkyard. The website http://www.car-part.com is great for searching the junkyard network for parts. Not sure what they call the part you need, but parts from an AWD Toyota Matrix of comparable years should be interchangeable
Posted: Thu Mar 29, 2018 8:41 pm
by BossSpud
joatmon wrote:welcome to genvibe
Thanks I will take a look at it.
Posted: Fri Mar 30, 2018 7:37 am
Another factor to consider is "how did this hole" get there in the first place? Is is from rust/corrosion? I'd assume that BUT you don't have location listed in profile so we have no idea where you're from. Assuming rust, you'll want to get a replacement part from a southern car so you don't go through this again.
Posted: Fri Mar 30, 2018 2:20 pm
by SeattleJeremy
If your alignment is currently in good shape, you could consider taking it to a shop that does metal repair work. Maybe they can clean it up, and weld on some new metal?
I'm reminded of the time the mighty car mods guys repaired the Mira sub frame https://www.youtube.com/watch?v=MFSaBPqfDoU
Posted: Fri Apr 13, 2018 5:47 am
by BossSpud
tpollauf wrote:Another factor to consider is "how did this hole" get there in the first place? Is is from rust/corrosion? I'd assume that BUT you don't have location listed in profile so we have no idea where you're from. Assuming rust, you'll want to get a replacement part from a southern car so you don't go through this again.
The hole came from salt. It was a PA car.
Posted: Fri Apr 13, 2018 5:48 am
by BossSpud
SeattleJeremy wrote:If your alignment is currently in good shape, you could consider taking it to a shop that does metal repair work. Maybe they can clean it up, and weld on some new metal?
I will look at that. I know a few shops.
Posted: Fri Apr 26, 2019 11:52 am
by zbyers
I know this thread is quite old, but I am adding this info for others in case they came across it...
Rear subframe can be replaced with one from the following vehicles
99-06 Celica GTS (GTS only as it had IRS, like the AWD Vibe
03-06 AWD Vibe/Matrix
09-10 AWD or GT/XRS Vibe/Matrix
All of these vehicles utilized the exact same rear subframe. car-part.com does not list these as interchangeable, but they indeed are. As these cars, and subframes age, it's nice to have this info available.
