2009 vibe 2.4 LT front wheel drive E-brake adjustment
Posted: Fri Dec 15, 2017 3:05 pm
My car has disk breaks all way round... AND the Emergency hand brake is incorporated into the DISKS in the back.
There is NO drum under the disk, or the little hole in the rotor that you can adjust your brakes with.
This method involves taking up slack AT THE hand lever in the middle console... MOST videos on youtube
Will show you there are FOUR bolts that have to be removed to remove the plastic center console.
ON THIS CAR there are only two bolts under the center storage compartment... BUT NO BOLTS have to
Be removed for this car. The CENTER piece of plastic that contain the two cup holder dividers, can be
Poped up... this piece has the leather cover for the brake handel.... Once this center is removed, on the side of the
Hand brKE ARE two 10mm bolts... THEY are tightened together. Loosen and remove the top bolt... then screw the remaining
Bolt colckwise to take up slack. BTW the brake handle should be released... Give it two full turns, replace the top
Bolt and tighten the bolts against each other... an open end wrench and a 10mm socket will do the trick... Test the
Hand brake and adjust accordingly.
GOOD LUCK
GOOD LUCK
