'05 Vibe Base - Replace front stabilizer bushings?
Posted: Sat Nov 11, 2017 8:48 pm
I need to replace the front stabilizer bushings on my father-in-law's '05 Vibe. ALLDATAdiy says the labor required is 3.9 hours, which is the same as replacing the stabilizer bar itself. Does this mean you can't just remove the two bolts on each bushing bracket and wrap the bushing around the stabilizer bar and replace the brackets? Do you really have to remove and replace all the same items as if you were replacing the stabilizer bar itself??
