interior lower B pillar - plastic trim coming off
canadave
Post by canadave »
Anyone had the problem mentioned in the title? The lower plastic B pillar trim cover is starting to come off, as if I was trying to remove it (but I'm not actually trying to...lol). It looks like the little thin tabs that should hold it in place are still attached to it, but they're no longer actually holding it in place for some reason.
2009 base Vibe, silver"
Re: interior lower B pillar - plastic trim coming off
Use https://www.gmpartsonline.net/auto-part ... llars-scat, change for your year and model, and find the part number for the clips. Some are probably broken. I just did this for some exterior moulding and a door panel and I bet your piece is similar.
