Buzzing noise when accelerating
Posted: Mon Oct 02, 2017 10:35 am
by kvnshnnn
I have a 2009 Vibe, 2.4L AWD, automatic transmission.
It's has started making a distinctive buzzing noise when I accelerate. It's almost like a really fast spinning propeller like noise. Seems to be coming from the engine compartment. I only hear it when the engine is wound up to accelerate, such as on a freeway on ramp to get up to speed. Otherwise there is no audible noise outside of normal engine noise.
Ideas? It almost sounds like an exhaust leak, but I'm just guessing.
Re: Buzzing noise when accelerating
Posted: Wed Oct 04, 2017 5:20 am
by ehoff121
Maybe a few more details on the noise would help?
High pitched or low? Does pitch change with speed? Does noise change in volume?
Exhaust leak would be low and you would hear it at idle and from under the car.
With no further information, I'd advise you to check for any loose hard objects (coins, CD cases, etc) in the storage areas that could be vibrating against a hard surface when the engine rev's are high.
Have a look at this thread, too: viewtopic.php?t=28211
Posted: Thu Oct 05, 2017 8:52 am
by kvnshnnn
Under normal driving conditions it's not audible. It is heard only when accelerating, at higher RPMs, when the engine is under most stress. Sort of sounds like when a kid puts a playing card on their bike such that the card is rubbing against the spokes of the wheel...sounds odd but honestly that's what it makes me think of.
Posted: Thu Oct 05, 2017 9:47 am
by ehoff121
kvnshnnn wrote:Under normal driving conditions it's not audible. It is heard only when accelerating, at higher RPMs, when the engine is under most stress. Sort of sounds like when a kid puts a playing card on their bike such that the card is rubbing against the spokes of the wheel...sounds odd but honestly that's what it makes me think of.
Okay, but is it highway speed you're traveling at or can you put it in neutral and hear it at the same RPMs?
Might help if you could post a recording of the noise.
Posted: Thu Oct 05, 2017 1:26 pm
by kvnshnnn
I stepped outside and started it up and revved it in both park and neutral. No noise. I'll try to get a recording of it when I drive home this evening.
